Riser change and wiring harnesses
The wife wants a 4" pullback riser on her 1200L. I have an extended brake line installed and ready to go. The other control cables have sufficient length to say on the bike but there is little slack in the wiring harnesses.
My question: Is it better to obtain extended wiring harnesses or to cut them and add 4"-5" of new wire in them?
Thoughts and tips would be appreciated if you have done this kind of mod before.
Thanks.
Thanks.
She has an 09, should have included that info. The wiring for the speedo and indicator lights is short by about 1.5" from getting into place. I could not get enough slack out of the wiring. Stripped off the tank and got into the cradle but there was not enough wire to pull. The hand controls are just long enough but it is very tight.
