stage one filter in a stock cover
You can either use a kn filter inside it or go the route most of us have and put the NRHS hurricane flow in. http://www.nrhsperformance.com/partshurricaneflow.shtml
The hurricane flow is what I have installed. I did the 2 inch centered model. It is a great kit and the company provides a top notch product and AWESOME customer service. This is why I went with them and I could not be happier. Go with the breather kit and bracket and go to autozone and get and extra length of hose.
Hope it helps.
MH
Hope it helps.
MH
Last edited by MechsHands; 03-25-2010 at 11:12 AM. Reason: saw the year of the bike nad edited some stuff
You will need to rejet and here is some info on that.
http://www.harley-performance.com/ha...arburetor.html
http://www.harley-performance.com/ha...r-jetting.html
https://www.hdforums.com/forum/sport...rejetting.html
Hope it helps.
MH
Hope it helps.
MH
It it's just reusing the stock cover, then hands down, the NRHS Hurricane Flow.
Thankyou for your replys!
l am new to this so l appreciate your advice.
Here's what lm doing.
V.H. Big Radius pipes, V.H. fuel pack and a new fuel filter, l know the V.H. fuel filter to match this set up for my bike but l dont like the round shape, l would really like to keep my stock chrome cover,
P.S.
female rider.
P.S.
female rider.
stage 1 refers to replacing the stock air filter with a free flowing air filter (choose one based on looks as the after market ones all function about the same), changing the pipes either with slip ons or a complete exhaust, and retuning or rejetting (depending on year of the bike) 07's and above require retuning/remapping with a fuel control management system like the power comander, and 06 and earlier requires rejetting.
When you replace the air cleaner changing the amount of air the engine gets, you will need to change the scheduling of the fuel via a PC3 etc because it leans out the mixture which causes it to run hotter and not as efficeintly and it will run roughly.
Hope this helps. There is alot of information about this int he forum. Search for stage 1, taxes paid, things like that.
MH
MH
MH
MH
A high flow (K&N) filter in the stock can isn't going to give you what's needed for Stage 1.
