please help
please help
Hey guys how are you first i havent been on i awhile .So i know where to go to get a anaswer hey is the prob.I went for a ride yesterday since it was awesome out and got home and realized there was a lot of gas on my air filter .Just to let you guys know alittle info i have a 06 883 with cycle shack pipes and rejetted the carb but no after market airfilter as of know iam thinking that might be the start of the prob.but not sure looked online alittle about it found a couple of things but nothing promiseing .so if you guy can please let me knwo something thanks in advance .and i know it has been talked about but i will ask again if you guys dont mind what is the best in your guys opinion for the airfilter setup i will be buying one of them soon and want the one that will produce the most hp for me.
I just had this same prob when starting mine for the first time after winter. The float in the bottom of the carb was gummed up a bit because I forgot to drain the bowl. Here's what I did and it ran better than it ever has. I put some gumout carb cleaner in the tank, shook the bike back and forth to mix it up, started it up and let it run a bit to get into the carb, shut it off and let it set a couple days. I shut the fuel petcock off and removed the air filter next time I started it. It started ran for about a minute while I sprayed some gumout carb cleaner into the carb. I then turned the gas back on and fired it up and prob was solved. I think just running the float bowl dry let the float fall down but the carb spray made it run much better. Hope this woks for you, it only cost me about $12 for the fuel treatment and the carb spray.
