lowering a sporty
Old 03-16-2010, 06:15 PM
low_wgn's Avatar
low_wgn
low_wgn is offline
Default lowering a sporty
i tried a search and didnt find anything but maybe i just didnt word it right. I was wondering if there is a way to lower the sporty while keeping the stock length shocks. Like some sorta block kinda thing. I ride 2 up with my wife at times and have some progressive 412 lowering shocks and we bottom out at times....was just trying to prevent this. Or are there other lowering shocks out there that are stiffer so we would bottom out when hitting bumps
Old 03-16-2010, 06:58 PM
woodworking1's Avatar
woodworking1
woodworking1 is offline
They do make a lowering kit. It is basically a piece that bolts on and lowers the position where the bottom of the shock mounts. However, lowering is lowering. there is no way to get around getting close to the tire. a stiffer shock setting might do the trick or stiffer shocks all together. I can't even fit my hand between my tire and my fender it is so close. I have my shocks set on almost the stiffest setting. I am however a lightweight at 165#. I jump it up to the stiffest setting when I ride 2 up. I also rerouted my wires to the side of the fender to prevent wear when I bottom out. It is only a question of "when not if" when I ride 2 up.
Old 03-16-2010, 07:41 PM
low_wgn's Avatar
low_wgn
low_wgn is offline
i guess the question is what lowering shocks are good to use riding 2 up
Old 03-16-2010, 08:11 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
The ultimate low cost lowering kit....
Old 03-17-2010, 07:43 PM
woodworking1
I have no idea about the shocks. Mine are stock. I'm sure someone here will have some suggestions.
Old 03-17-2010, 08:51 PM
Twisted Noodle's Avatar
Twisted Noodle
Twisted Noodle is offline
I have the shocks off of a XL883L which is 10" eye to eye. I have it set on the lowest setting and ride 2-up and it does not bottom out...for short trips anyway..
Old 03-17-2010, 10:46 PM
lilbruce's Avatar
lilbruce
lilbruce is offline
I was looking to lower my 883 and I couldnt find anything...
Old 03-18-2010, 09:22 AM
Zimbob's Avatar
Zimbob
Zimbob is offline
Like stated above, lowering the rear will get the rear tire closer to the fender, wether useing blocks or shocks. Stiffen the shocks up when rideing two up. On my Roadking, when rideing two up, I add 5 to 8 lbs of air to my shocks to keep things rideing good.
Old 03-18-2010, 10:53 AM
lilbruce's Avatar
lilbruce
lilbruce is offline
Thats what I need is some air ride shocks!
Old 03-18-2010, 01:44 PM
will227457's Avatar
will227457
will227457 is offline
RK shocks...buy some
ok now someone owes me a nickel
Quick Reply: lowering a sporty
