Brake light won't turn off
Took a look over the previous threads...couldn't find one that was relevant to the issue I'm having.
Here's the deal...the brake light will not go out on my 08 sportster 1200. I turn the ignition on, and both the taillight element and brake element illuminate. I checked the wiring that runs beneath the fender, and found the brown wire had been pretty terribly frayed. I fixed that, and inspected the taillight assembly, but can't find any other reason that this is happening. Any ideas?
Thanks for the quick replies all around.
So if I'm looking to check these switches to see if they're stuck...where exactly should I be looking?
And I did recently swap out my handlebars, but after fitting everything in place, the lights still functioned properly, so I'm hoping there's not damage to the lever control itself.
