handlebars ?
You could go with the stock bars from an 883L, and angle them back as needed. If you go risers, you might want to look for some that have some pull back.
I am currently making some bars and I used some PVC pipe and elbows to make a mock set. You could do the same thing and play with the height and angle.
I suggest you also consider wider bars like on the Nightster. The narrower bars on the Iron make it more difficult to control at parking lot speeds.
Don't ignore the possibility of 10" mini apes....Higher bars give you lots more leverage when tossing the bike around and also holding it up at stop lights.
I installed 10" T-bars on my Iron recently and absolutely love the height and extra width...check the pics out in my Myspace. They are in the 'Christmas for Black Bitch album'
Drag bars with a nice amount of pullback will greatly increase your comfort. My wife has these on her sporty and they rule. http://www.wild1inc.com/orderWO560.html you can sit completely straight up with the amount of pullback on them. I can get you a great price if interested too.
Looking to purchase new bars for my 08 1200L. Still have the stock bars on mine. On long rides my right hand will go to sleep and I use the throttle lock down the interstate at times to revive my hand. I like the mini apes with a good amount of pullback. Live in the coumtry so I have a lot of twisty's to neogotiate as well. Do I need to go to the local bike shop to be fitted for bars? What is yall's advise?
thanks
thanks
I too am a shorty. I have an '09 Iron. I bought 12" mini apes cuz I've grown attached to them. I heard it's a mess to install them myself due to the clutch cable and the risk of draining the primary. My boyfriend is more a mechanic than I... is this a do-it-yourself job or should I be taking this to the dealer. Bike has less than 500 miles on it (incase that matters.)
Thanks!
Thanks!
Phat Performance, but don't buy them. The internal wiring holes are in the wrong places under the switch housings and the tubing under the right grip is squashed out of round in manufacturing......It took lots of rework and repaint to make them right.
Besides that, last time I looked they no longer stocked them.
some1 got the nightster bar for their iron and got better reach , im on a nightster and a bit short on reach during longer rides my back sort of stretches , but i feel very well on the bars from an 883L/1200 L slightly wider and little pullback you sit try that one , only havnt changed to those bcuz need to change wiring
