fuel pump squeal
03-04-2010, 03:38 PM
fuel pump squeal
The wife's bike is an '08 1200 Low. If the bike isn't started for a week or two, it makes a squealing noise when you first turn on the key. I think this is the fuel pump getting gas to the injectors for it to fire. After it starts once it never makes the noise again unless it sets for a while. Any thoughts?
03-04-2010, 04:54 PM
It happens when you let it sit too long. Its being primed with fuel. Nothing to worry about.
03-04-2010, 05:03 PM
Same thing happens with your car, if you listen closely. It's normal as long as the pump only runs for a 2-3 seconds and stops.
03-04-2010, 06:50 PM
I have a nightster and it does that every time i turn the switch to run. It is high pitch and louder than normal but i have heard it like that on a ton of bikes so it is normal.
03-04-2010, 07:31 PM
I have an 09 883L and my fuel pump makes the squealing noise if it sits for a while too.
03-05-2010, 11:06 AM
Thanks for the help. It's good to know it seems to be a common problem and not any trouble. Thanks again!
09NightsterVB
07-09-2010 07:28 PM
rich1374670x
08-22-2009 09:47 AM
jcain
04-23-2009 09:43 PM
nightsterman
07-28-2007 11:34 AM
davidwideglide06
05-02-2007 07:09 PM
08 ,
davidson ,
fuel ,
harley ,
harleydavidson ,
high ,
making ,
noise ,
pitched ,
pump ,
sportster ,
squeak ,
squeaking ,
squeal ,
squealing ,
squeeling
