Nightster wont START, Help Please
OK guys, i need help on this one. I am trying to figure out why my bike wont start and i ready to say i need help.
When i go and start the bike it does the following:
Last summer i had a problem with the lights that made the bike act wierd but it would still start. I fount out that the left rear turn signal wires go rubbed by the rear tire. I repeared it and it ran fine for the rest of the summer. Could this still be related to my problems it am having know?
What i have done so far:
Any help would be greatly appreciated.
Thank you
LF
- Turn inginion to on. (light come on and the blinkers flash from right to left several times and stop. I dont remeber it doing this?
- Turn handle swith to run (i hear the fuel pump come on)
- Press the start button and "NOTHING". No clicking or nothing, just dead.
- It seems to be intermitant, if i repeat this process a couple times it sometimes starts
- Checked the rear turn signal wires, seems to be OK
- Checked all the fueses, added dielectric grease.
- Relays seemed to have some corrosion, cleaned tabs and reinstalled
- Checked Gound on the chassie from the battery, cleaned but it looked OK.
- Checked the possitive terminal on the battery, looked good.
Thank you
LF
Do you have the factory alarm? With the factory alarm when it gets mad the blinkers flash back and forth. Then since it is mad it won't let juice run to the starter, because it thinks you are trying to steal it.
If you have the factory alarm make sure you have the fob by the bike when you are trying to start. If you do not have the factory alarm I would say the battery does not have enough juice to turn over the starter.
