Breather again
1 Post
Breather again
I have read everything here about stage 1 breathers and heavy breathers. Just when I think I have made up my mind to do the upgrade, I get thinking about heavy rain causing problems especially for the heavy breathers. Since I like to drive long distances on my Sporty, should I stay with something that will fit inside the ham can ? I don't want it to die duriing a heavy downpour. Right now, in stock condition, it runs well in the rain. Should I take the chance ? Helpful suggestions, please.
your breather is gonna be fine...
another thing you can do (i did) if you want to keep stuff outa the breather- like oil- is to put on a "breather blow-by". i used to get oil in the breather, but no longer.
more info in this thread:
http://xlforum.net/vbportal/forums/s...56#post2305656
mine is very simple and just runs across the lower part of the engine under the breather to under the bike.
you can see it if you click this pic to open it large (open this and then click on the pic to make it large so you can see my breather tube):
http://www.s2ki.com/forums/index.php...age&img=682236
not to hijack but....i shouldn't be alarmed at the oil blowin through my ness II guys? ive heard if you let the bike warm up a bit before you get on and start hammerin you may not get as much, although i know it has a lot to do with oil level.
