tire pressure discrepancy
Was going over my 09 XL1200C, which has OEM tires.
Looked at the sidewalls and noticed the manufacturer, Dunlop, recommended cold pressures of 41psi front and 40psi rear.
The owner's manual, page 23, says 30 front and 36 rear.
Not too much difference on the rear, but an 11 lb difference in front seems like
quite a bit.
Thoughts?
quite a bit.
Thoughts?
SportyPig is correct one this. The pressure listed on the tire's sidewall is a MAX pressure at GVWR for the tire. The tire manufacture's installed inflation recommendation will often vary depending on the weight of the vehicle on which it is installed.
If you are running the stock Dunlops then you should refer to the Owners Manual.
If you are running a different make/size tire, you should refer to the tire manufactures website for the correct inflation for your specific vehicle.
One theory is that a slightly lower pr such as 32-34 will put a larger patch of rubber on the road...better stopping.
Another theory, from the motor cops and anyone that uses Michelin is to use the max pr listed on the tire. This is to prevent sidewall flexxing when max performing the tire.
Bwana
Bwana
Those of us that have enough miles under our belt to have been through several sets of tires from different manufacturers, know that all tires do not perform the same. Likewise, it only makes sense that each tire's manufacturer has a set of specifications under which their tire achieves optimal performance.
What was good for tire brand "A" 20 years ago, is not necessarily what is optimal today for tire brand "B".
