Screamin Eagle air cleaner problems, documented fact or fiction
Not correct. The SE kit comes with a washable gauze type element much like the K&N only the gauze is more dense and does not get oiled. I used K&N's for years then grew weary of the oil thing (not enough and won't filter well, too much and makes an oily mess). My SE kit with the SE element works just fine thank you.
I have a 07 1200C that I want to start upgrading, and I have purchased a SE air cleaner setup for it. I have read a few things about the possibility of the backing plate warping, and am wondering if this is true. Has anyone had it happen? Is it only certain models? Should I go with a Ness Big Sucker instead?
Thanks,
Jason
Thanks,
Jason
over 20.000 miles here, no problem with the backplate or screws gettin sucked - I check them regularly tough.
the filter media, on the other hand, is crappy and got replaced with a k&n HD-0900 a long time ago. that POS rusts the screen and the rubber and foam parts desintegrate, not to mention the filter media develops little holes in it.
cheers
cheers
Thing is, when someone is doing some research and these posts come up from that search, it helps when the correct information is presented. Doesn't matter how old the thread is.
