check out these wires.
I was out ridding the other day and I noticed every time I touched a brake front or rear,my right indicator warning light came on and then it started showing the red key(ignition.)
So when I got home I checked out the wiring first the mod I made when I put on the drag bars,no luck.
But then I thought damn those wires running over the frame under the seat.I found two lots of flattened leads running to brake and indicator,so I rounded them again and I have now wrapped that hard plastic spiral cable neatening megafta's around the areas that get pinched between seat and frame.
Problem solved.
Problem solved.
ManicKernel
04-07-2012 07:31 AM
