Tire repair's
Hi everybody, just wondering what you guys do if you discover you have a flat front tire that has spoke wheels? Is there a repair kit to fix such a problem while out driving. I carry a plug kit in my truck and car, but they are tubeless tires so no problem. But tube tire's different, any suggestion's. Thank's all.
I was told by an indy that if the damage is minimal (small puncture or cut) you can save the tire and just replace the tube. If damage is greater, you may have damaged steel belts sticking out and replacing the tubes alone may not work.
I ran over a utility knife blade about a month back and they tried just replacing the tube. Once repaired, they slightly over-inflated it to see what the hole would do (as if you hit a pot-hole). In my case, it bulged big time and the tube almost pushed through!
New tube, tire and mount = $211.
