Harley Forward Controls Under $150.00!
Mid brake control pictured:
The mid brake lever's pivot point is towards its bottom. The forward lever has the pivot on the side. The shorter mid brake rod has pivot joints that are nearly perpendicular - the forward's ends are parrallel. The pin for the break lever (top of photo) is longer on the forwards set. I'm guessing 42652-04 Right Side Brake Peg Mount 2004-present $38.95 does not include the longer pin or brake lever. The shift lever for forwards is waaaay different than mids. Maybe I'm missing something here, but I'll wager you're going to need more than those four part #s.
Let us know how it goes and post a pic.
I just found this incase it might help anyone else out, even though the PN's are already posted. It's here Harley PDF for the Forward Controls
http://www.harley-davidson.com/en_US...ts/-J04006.pdf
You certainly don't follow what you preach!
THERE'S A LITTLE BIT OF MIS-INFORMATION IN THIS THREAD. DON'T THINK YOU'RE GETTING OFF CHEAP!
I don't know how else to say it.
For those wanting forward controls and not wanting to spend $300+ here's a list of Harley parts that will convert your current mid controls to forwards for less than $150.00! These are referenced from the Harley parts manual. I used my 2007 Low to try this out and it works perfect. You are saving money by not buying the pedals and one shift linkage part which are already on your bike. Just ask for these parts off of a C model to make it easy,they are all interchangeable.
Left Side Shift Peg Mount 2004-present $35.95
Shift Linkage Rod 2004-present $28.00
Brake Rod 2004-present $36.30
Total $139.20!
If you want a Chrome set of peg mounts,you can get them for $94.99 or $20.00 more!
These are list prices,so if you get a HOG discount or some type,you can save even more.
The only thing you have to do is loosen your transmission shift arm,remove the peg and point downwards to connect your shift rod.
Hope this helps someone.
Total $139.20!
1lowsporty- Since you were able to successfully perform this mod, can you post pics of your forward controls.
