Too much oil?
RE: Too much oil?
First, take it back to the dealer that did your service and tell them to fix it! Second, for future reference, always check the "0" ring on the oil cap and make sure it is lubricated and not cracked. If it does not seat and seal properly, you will leak oil at the cap.
Thumper26
Thumper26
RE: Too much oil?
Have you checked the hot oil level on the dipstick to see what it reads?
It might be a bad gasket, or it could be overfilled. Hard to tell without checking the actual oil level in the tank.
I try to keep my hot oil level at, or just slightly below the halfway mark of the dipstick.
You don't want to overfill the tank.
RE: Too much oil?
To answer your question... yes, too much oil can be as bad as too little. It's such an easy fix.... just open the drain tube and let some out.
There has been several times I've over filled mine just a tad had the same problem as you discribed, but I just pulled the plug and let a little out... problem solved.
Harley's 3.6 quarts less the 4 oz for the filter is a pain.... but not a big problem.
Charlie D.
Charlie D.
