Damn. Just stripped the O2 sensor. What would you do?
Old 12-23-2009, 06:27 AM
oinker02's Avatar
oinker02
oinker02 is offline
Originally Posted by Dango
Thanks jag, that's just what I did. After checking with 4-auto parts stores and an indy cycle shop I realized that an 18mm tap and/or die just wasn't to be had. The threads cleaned up pretty well it went back in. It was a little tough but it works. WTF just realized I forgot the anti-seize! Back out they come.
Thanks for all the advice everyone.
Stop!...If you got them to rethread, then don't stress the threads again to apply anti-seize....Just forget it or maybe regret it.
Old 12-23-2009, 06:32 AM
oinker02's Avatar
oinker02
oinker02 is offline
Originally Posted by mtairy biker
i think they even make a hi-temp anti sieze
Well, FERSURE!..............seeing as how there ain't no such thing as low temp anti-sieze, then you can kinda be certain it will be hi-temp if it's called anti-sieze.
Anti-sieze is a high temp thang by nature, ya know? Low temp stuff is called grease.
Just sayin..............
Old 12-23-2009, 10:29 AM
Dango's Avatar
Dango
Dango is offline
Ain't no way I'm removing the "jacked-up" sensor again! I did, however, take the good one out and lubed it up. Thanks oink.
SouthernWalker
08-22-2015 08:05 PM
Stang951
08-04-2014 10:30 PM
djwhaley
11-17-2013 03:28 PM
WideGlideFever
01-29-2013 08:22 PM
UT-rckr
06-29-2011 10:54 AM
Quick Reply: Damn. Just stripped the O2 sensor. What would you do?
