stretched frame and swingarm
What kind of 2:1 is on that rigid?
Thanks. That exhaust, i made with a buddy of mine who owned a performance exhaust business. We made it out of stainless Steel and slapped a supertrapp aluminum 4"canister which is tuneable. The Bobber is a hi compression 80" with 111rwhp and only weighs 569 lbs. and is completely powder coated
I built a 2" longer swing arm for my bike from 2 old junk swingarms I bought on EBAY, I cut them up and had a local machine shop make a solid steel slug to go inside and welded it all back together, works great, it's been on the bike for several years now. I have about $70 in the whole thing.
this is way cool! i'm wondering why you did it?
Drag bike look and the bike does put 85HP to the ground so it's running around what a Buell puts out and when you lauch it now the front end stays down and it flat hauls *** off the line. I also limited the shock travel to 3/4" of travel so it basically is a hard tail with just enough travel not to bust you *****.
Strectched swing armsss
Hello...How much would you charge me to strech my swingarm for 2003 harley road glide..I have two swing arm that you can use..A 2 inch stretch..If you can..Please email is kendrenfranklin@yahoo.com...Thanks
Belts are not a problem to get (For a 2" stretch), but as you know. They cost a good bit more than stock. =\ Some people just switch to a chain anyways, especially when they want a wider tire. For a wider tire, you have to convert to a chain anyways.
I moved and lower the rear fender on my bike to make it match the swing arm. I will not make one of these for anyone they are a bit of a PITA just because Harley does such a crappy job welding there swing arms together, I found at least a dozen spots on the 2 arms I used that had no penetration when welded for the factory, if you know how to weld it's a good project to do but it takes time and patients to get it right.
Here's a few photos of the project
timsmcm
12-29-2013 09:09 PM
