Scotch Brite is the SH*T!
Old 12-12-2009 | 02:27 PM
xxxflhrci's Avatar
xxxflhrci
Should be call Scratch Rite, instead of Scotch Brite.
Old 12-12-2009 | 04:40 PM
killer scott's Avatar
killer scott
I still havn't heard a response to the "will it rust?" question from someone first hand... Anyone had theirs on there for a year or more?
Old 12-12-2009 | 04:41 PM
xxxflhrci's Avatar
xxxflhrci
Yes, if you scratch the chrome enough it will rust. Chrome is intended to protect the steel.
Old 12-12-2009 | 04:46 PM
BoomerBob's Avatar
BoomerBob
It's also great for scuffing bare metal to prep for painting.
Just saying ...
Old 12-12-2009 | 04:54 PM
2003Springer's Avatar
2003Springer
good to know even though I will never use it on my bike. Made it right when I made it bright
Old 08-27-2010 | 05:09 AM
Pixiechitos's Avatar
Pixiechitos
Yeah I did mine a while back, kept to straight lines and it looked awesome. Then I took some steel wool (fine) and did it again, because the steel wool is so fine there are no lines visible, it sort of polishes it out. I love the look...even scotched the shock caps and my chrome turn signal stems.
Old 08-27-2010 | 07:34 AM
WRAITH's Avatar
WRAITH
Blackfire Wet Diamond metal sealer will protect the brushed chrome.
Old 08-27-2010 | 09:01 AM
Pixiechitos
Awesome!...If only we had it here in South Africa
Metal Sealer...at a hardware shop I suppose?
Old 08-27-2010 | 11:30 AM
Guest
Guest
Posts: n/a
Yes, it will absolutely rust. How soon depends on how much chrome you remove, but it will eventually rust irregardless. Good clear coat paint will help prevent the rusting, as will diligent maintenance (i.e., clean it often, and steel wool rust spots off as soon as they appear).
Old 08-27-2010 | 11:36 AM
Pixiechitos
Yeah I figure, I'll keep scotching them clean till I get new pipes next year or so. I'm wondering if I'd find any kind of clear coat that can stand the heat. Anyway...removing the heat shields and wrapping the headers so its only the mufflers to think about...LOL, I could always remove the mufflers ^_^
Quick Reply: Scotch Brite is the SH*T!
