Riser handlebar question on 2004
Hello everyone
I just bought a Z handle bar for my Sportsrer 2004 and i wonder if it is possible to have the oem riser remplace by 2 inches riser that will fit around the oem light panel lights integrate speedo ??
Thank you
Any help will be very appreciate since i should ask befire buying the Z bar
Thank you
If I understand you correctly...You want to use the original speedo set-up, but drop the oem riser 2 inches. What are you on? You said a 2004, but what model 2004? If its a custom your speedo will be hitting the tank if you take 2 inches off the bottom. But maybe I'm not understanding what your trying to do.
If you do the cyclonecutting mod to your riser, I'd be willing to buy the piece that gets cut off the bottom if it isn't destroyed in the process.
I've been thinkin about buying a riser just to get a 2 inch piece from the bottom to use as a spacer to heighten my stock riser. Let me know!
AzDon
azdon@yahoo.com
AzDon
azdon@yahoo.com
