07 FX wheel mod
Old 12-06-2009 | 07:37 PM
RacingJake's Avatar
RacingJake
I bought a 23 tooth .50" offset sprocket from J&P # 6000008 for 34 bucks and using a 51 tooth rear sprocket for a 2.22 ratio. Had to add an extra spacer to the front and rear sprockets too and also one to the rightside of the rear axle cause the sprocket bolts would touch the swingarm.
My bike an 01 but if your's is newer with the one inch axle you may not need to do much cause I hear it's an easy swap cause you already have a wider swingarm to begin with.
Hope this helps
Old 12-07-2009 | 01:00 AM
mreed's Avatar
mreed
Thanks for the info. Mine's an 03 & I'm pretty sure we have the same swing arm. My bike also has 3/4" axles.
Thanks for the heads up on the offset sprocket.
Old 12-07-2009 | 09:34 AM
RacingJake's Avatar
RacingJake
If you get a wheel with 1" bearings then you can replace them with 3/4" bearings and your good to go. You may have to clearance the inside of the front sprocket cover cause the chain will be really close, but that's easy to do.
I added a second rear spacer .100" to the one that can with the offset sprocket, and I don't remember the size I used on the front sprocket but it's flush with the splines on the shaft. Also the center hole of the spacer may need to be file larger due to the lip on the wheel.
I don't think you can go any bigger than a 160 tire and 4.5 rim on a solid mount bike without major work ??
Old 12-07-2009 | 02:35 PM
mreed's Avatar
mreed
I added a second rear spacer .100" to the one that can with the offset sprocket, and I don't remember the size I used on the front sprocket but it's flush on the shaft. Also the center hole of the spacer may need to be file larger due to the lip on the wheel.
Yep. They had 1" bearings when I got em. They're 17x6 & I'll be using a 180/60-17 tire. I'm not sure what you mean by a solid mount bike but I don't plan on changing much on the swing arm. I want it longer (just because) and I might go 1/2" wider or so. These Roland Sands wheels have been challenging but surprisingly simple to fit. The hubs are removeable so I can adjust pieces here & there...turn them down...
Old 12-10-2009 | 10:49 AM
RacingJake's Avatar
RacingJake
WoW a 6 inch wide rim, that may take alot more work to get it to fit.
Good luck, but I think you may have to widen the swingarm, cut the frame to widen the struts and go with a bigger front offset sprocket than an .50" on a 03 solid engine mount bike.
Old 12-10-2009 | 09:09 PM
mreed's Avatar
mreed
Ahh...gotcha.
I already have the wheel fitted. Waiting on tires now. The front wheel, actually has been more of a pain than the rear. I'm tellin ya...Roland Sands's bolt on hubs has made it much easier.
When my chain sprocket comes in from Performance Machine I will see what I need to do to modify the swing arm. It looks like I'll need to widen just the right side 3/16" and extend it for tire fitment. I wanted to extend it anyway to fit a mono-shock in front of the rear tire.
Thanks for the info. The only sprocket they had available to match my wheels is a 48 tooth. Couldn't I just adjust the aspect ratio on my tire to compensate if needed?
Thanks again! You've helped my motivation.
Old 12-10-2009 | 09:17 PM
mreed's Avatar
mreed
Here's a pic of my front wheel just hangin out. I'm going to turn some narrow glide hubs this weekend.
I will be spreading the frame. I have a cool idea on how to make it look pretty much stock. (you can see my "mono-shock" shockwave air over shock on the ground by the rear wheel.)
To continue my question from my previous post, I plan on running a 180/60 17 tire (25.5" diameter). What front sprocket tooth count would keep it close to what the stock ration was...again, I can run a taller or shorter sidewall if needed, if you don't mind my pounding the questions.
Thanks again for your help.
Old 12-11-2009 | 08:32 PM
RacingJake's Avatar
RacingJake
That is an awesome project you got there. Those are some nice wheels $$ I like the mono shock too, is it going above or below the swingarm ?
With the 48 tooth rear a 23 T front will give you 2.086 ratio and a 22 will give you 2.181 ratio. 2.10 ratio is stock for a 1200.
If your like me you'll find yourself just staring at those wheels saying damn they look good in there !
Old 12-11-2009 | 08:47 PM
mreed's Avatar
mreed
Thanks man!
The monoshock will go from my stock fender bolt cross bar down to the swing arm. I have a tiny compressor to have onboard air management. I took it apart to powdercoat & chrome it since I'm not going to be able to completely hide it.
Thank you for the info!
Copper&Black
General Topics/Tech Tips
04-01-2017 01:23 PM
dennyo
01-08-2013 12:07 PM
dennyo
12-12-2012 07:30 AM
busij44
EVO
18
07-18-2012 08:28 AM
orangecrush
05-09-2007 10:27 PM
Quick Reply: 07 FX wheel mod
