Cracked Swingarm
Cracked Swingarm
I was in the process of cleaning the swingarm prior to replacing the chain and sprocket, and noticed a little paint had lifted just befor the axle. Upon further investigation I found my swingarm was cracked. Has anyone here had this happen on theirs?
can this be safely welded, to repair it?
Glad you discovered it before it put you down or into oncoming traffic.
Yeah, that and all kinds of other stuff on our scoots crack n break or work loose. Hopefully, all who read this will learn to take lots of time to go over their bikes routinely and objectively LOOK for such problems before they splatter you.
Ten years ago I was an amusement ride inspector for the state.....I saw things then that made me swear off ever again riding another roller coaster.......I see things on scoots (including mine) that make my butt pucker, but rather than not ride, I learned to instead look for the problems almost daily and stay on top of them.
Gents.....there might be a day when you are layin beside the road bleeding out due to a failure on your scoot that will instead be attributed to "rider error"....Don't fall into that stat......Take time to comb your ride like your life depends on it-because it really does.
It would be interesting to know the area to check for problems.
I'm surprised this doesn't come up more often, I built a 2" longer swing arm for my bike a couple of years ago and the original Harley welds where so bad on the swing arms that there was rust in between all the pieces, it was a total pain in the *** to repair everytime you thought you had it done you would find more rust where the welds hadn't penetrated.
