Diag Codes on my 04 custom
Hi I have the list of trouble codes for my bike. But it does not tell me a lot really. So any kind of help is welcome.
The module is a pn 68980-4 which i believe is a tssm module.
the codes i got are under
S: b1141, u1301
SP: u1255, u1301
The bike runs good i have some modes done to it. Like Dyna ignition module and hi comp pistons and so.
Also i dropped her a couple of weeks ago no major damage just a couple of scratches.
I put on apes and i'm afraid i screwed something up
Thanks
S: b1141, u1301
SP: u1255, u1301
Thanks
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
S - B1141 - (TSM= Turn signal module) Ignition Switch Low/Open..
U1301 - Serial Data High..
SP - U1301 - ECM Serial Data High
U1255 - Serial Data Error
now me telling you how to fix these that is a different story. Some one with a little better knowledge may chime in and give you more info. This is just what the codes are telling you.
SP = speedometer
SP = speedometer
SP = speedometer
Thanks i got the codes but dont really know what they mean. and since the bike is running fine whta to do about them
Did you try erasing the codes? See if they show up again once erased.
There is a bank angle sensor located inside the TSM/TSSM. The BAS will shut the ignition off, if the lean angle exceed 45 degrees for more than one second. Once the sensor is tripped, the motorcycle must be uprighted, turned off and then on again before the engine can be restarted. The BAS signal is delivered to the ICM via the Serial Data Link circuit from the TSM/TSSM.
You say you dropped the bike, it may have tripped the BAS ... giving you the error code.
2black1s
02-04-2011 09:24 PM
