You'll get a chuckle over this!
07-06-2006, 11:20 PM
I'm changing the grips on my 2003 sporty xl883c . Someone told me I had to cut the grips off in order to put the new ones on , Is this true? If not how do you accomplish this task. I TOLD YOU ,YOU WOULD GET A CHUCKLE!
07-06-2006, 11:28 PM
RE: You'll get a chuckle over this!
You have to cut the left grip off, and it's accomplished with a knife.
07-06-2006, 11:34 PM
OK,HEH HEH, HOW ABOUT THE THROTTLE SIDE
07-06-2006, 11:57 PM
Technically, you don't have to cut off the left grip. You can try some other tricks to get them off but they are time consuming and involve man handling. I would just cut it off and be done with it.
If you get a set of glueless grips you won't have to cut off the left grip.
07-06-2006, 11:58 PM
Throttle grip isn't glued on, that's why you can twist it. It comes off after you take off the right switch housing.
07-07-2006, 12:03 AM
boiling water poured over the grip expands the rubber, and then brush "Goof off" around the bars where it meets the grip and it will pop right off.
07-07-2006, 12:13 AM
A heat gun can help too... but who's saving the stock grips???
07-07-2006, 06:28 PM
I used a screw driver to work it off. it took all of 5 minutes. then used a little shoe goo to keep it in place.
straps
03-15-2011 07:03 PM
jmorris42
02-21-2011 10:40 AM
2007fxdc
12-10-2009 09:01 PM
wolverine66
04-02-2008 08:26 AM
twoseas
11-29-2006 06:34 PM
