Need new tires soon
You do not necessarily have to change both at the same time ... normally the rear will wear faster than the front. If you follow safety guidelines/tread depth the rear will need be changed before the front.
However, due to the age of a tire it will develop dry rot ... I would check for small dry rot cracks on the sidewall of the front as well. There may still be some tread life left ... but the dry rot will weaken the tire ... which could lead to a blowout.
Sorry, I missed that. Generally speaking, it is not necessary to replace both at the same time. With a 19" front wheel, it is common to go through 2 rear tires for every 1 front tire. If you have a 21" front wheel and run the twisties, you may wear out the front tire well before the rear.
1 Post
Tires are such a gamble. If you like the ones you have, simply replace them with the same thing. If you don't mind trying something new, do it. The gamble is if you don't like them then you are screwed. No test rides as far as I know. My local Indie is really good. He will not replace anything unless it has to be. He replaced front tire (not worn completely but showing dry rot cracks. He said back ok (original tires) I would get a summer out of it. I did and replaced it this spring. Metzler. I gambled and Love them. Grabby! love the feel of them in the turns especially. I can't remember the total cost but very reasonable and he did the work. Chopper Rod's in Fredericton NB, Canada
Many of the local shops will want to rape you on mounting the tires. The first time I needed tires, I ordered them online first, and then started checking for someone to mount them. Most of them wanted to make the same profit as they would make if they had sold me the tires.
Check around and find someone that will mount and balance the tires for a reasonable price first. I finally found a guy that mounts and balances tires for me that charges $15 per tire. That is with me removing the wheel and taking the wheel and new tire to him.
When you guys say you only had the indy mount and balance, is that including mounting the new tire on your rim or just throwing the tire on the bike? I don't have the equipment to swap tires on rims, so I'd have to have a shop do it all. Theres a few dealers and a few indys around me I can call to see what they'll do
1 Post
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
![Icon Cankick](https://www.hdforums.com/forum/images/smilies/icon_cankick.gif)
