Clutch cable adjuster
Old 10-25-2009, 10:00 PM
BlackBikeDave's Avatar
BlackBikeDave
BlackBikeDave is offline
Default Clutch cable adjuster
Not sure why my adjuster has a thumb wheel type adjuster and not a 6 sided nut style. I watched the vid from the forums on adjusting this and once the guy adjusted it he used 2 wrenches to tighten and lock the new setting.
I have had 2 occasions now where the adjustment loosens and I have to turn the bike off because I cant get into neutral.
Is this just a case for thread lock? I am very frustrated and it seems it could become dangerous for me.
Old 10-25-2009, 10:22 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Are you talking about down the clutch cable under the 'rubber boot'?
You should have a cable adjuster (1/2" fitting I believe) and a lock nut (pretty sure it's 9/16")..
I don't know why you would have a thumb type screw for setting the clutch cable.
Old 10-26-2009, 08:33 AM
BlackBikeDave
Exactly! Why would there be a thumbscrew there instead of a nut you can tighten. The bike is stock and I think it is the stupidest thing in the world for there to be a thumbscrew there. How in the world can anyone think that is a good idea with all the vibration? I guess I will have to have that changed. I dont want to be pulling over in the cold dark to keep adjusting this shitty thing.
Old 10-26-2009, 08:39 AM
OldFenderGuy
Strange.
What year bike is it?
Happen to have a picture showing the adjusting 'wheel'??
I'd hate to think that the newer models are using a clutch adjusting setup in which there is no "locknut" to hold the setting in place... That would be crazy, and could be dangerous as well....
Old 10-26-2009, 02:29 PM
NightsterAl's Avatar
NightsterAl
NightsterAl is offline
Weird. I just put on a new clutch cable. Both my stock 07 and new cable had and adjustment and lock nut on it.
Old 10-26-2009, 03:24 PM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by OldFenderGuy
Strange.
+1 - Never seen or heard of such an arrangement.
Please post a Pic.
Old 10-26-2009, 03:55 PM
3rdgear's Avatar
3rdgear
3rdgear is offline
Can you get us a picture of it?
Old 10-26-2009, 06:11 PM
Sundog's Avatar
Sundog
Sundog is offline
Are you the first owner? Perhaps it has been replaced with a nonstandard cable. Many other brands have used thumbwheel style cables. Maybe it was substituted in a pinch. Buy a stocker and replace it.
Old 10-26-2009, 06:26 PM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
seen the style that adjust at lever with a starwheel,but one where there should be a nut crazy ****. that would be a pain in the azz.
Old 10-26-2009, 07:21 PM
BlackBikeDave
Is this crazy or what?
Quick Reply: Clutch cable adjuster
