1984 Sportster XLX Gen Light
Old 10-25-2009 | 12:38 AM
Paycheck's Avatar
Paycheck
Stage III
Default 1984 Sportster XLX Gen Light
OK, I checked the Gen,Battery,& volt pack. (Gen light )stays on i can run the bike roughly 100 mi shut her down for fueling and wait for a jump I believe it may be wiring however I had a bad battery last summer i replaced the battery,then had a local shop test the Gen that's when this problem began. I'm just wondering if anyone else has had this sort of problem.
Old 10-25-2009 | 01:10 AM
83XLX's Avatar
83XLX
Have you checked the voltage regulator to make sure it's good, and made sure the generator is polarized correctly? Other than a wire loose somewhere, those are the prime suspects.
Old 10-25-2009 | 02:11 AM
Paycheck's Avatar
Paycheck
Stage III
yes tried swapping the volt pack light stayed on also checked the wiring and couldn't locate a bad wire. I'm going nuts trying to figure this one out.
All Aces
02-08-2018 09:00 AM
01DynaLow
10-12-2016 09:57 AM
OBXPAUL
04-08-2011 01:42 PM
Paycheck
10-25-2009 12:42 AM
bucaman
Ironhead
20
07-04-2008 10:58 AM
