does anyone else have a 2006 with carb cough?
Old 08-14-2006, 07:19 PM
ionate's Avatar
ionate
ionate is offline
Default RE: does anyone else have a 2006 with carb cough?
ORIGINAL: Rynb15
mine was really bad when i first got. Then i started running 93 octane gas and its way better. Almost completly gone at warm up.
Is that an 883 or 1200? I have an XL883 and I'm wondering myself if I shouldn't try 89 octane.
I seem to have a lot of coughs coming out of the exhaust as well as the carb.
Old 08-14-2006, 07:21 PM
ionate's Avatar
ionate
ionate is offline
ORIGINAL: brendajmull
thanks for everyones replies, dh messed with something in the carb last night and says the cough is gone!!! I am agoing out for a ride in a little while to check it out for myself..I hope it is gone...
Soooo... what did DH do exactly to the carb? Adjust in anyway?
Old 08-15-2006, 03:24 AM
Crossbones's Avatar
Crossbones
Crossbones is offline
sounds like dh may have adjusted the idle screw, since you notice it running faster as well. use the higher octane as well. you didn't mention what mods you have on the bike, which might help answer it. good luck...
Old 08-15-2006, 12:32 PM
dg7080's Avatar
dg7080
dg7080 is offline
My 06C has had carb cough since day one and I've about decided it's not ever going to be cured. It came from the factory with a 42/180 jet combo.
At 1k, I put SEII's and the SE high flow air filter on myself, then had the dealer rejet for me during their 1k service. They put in a 45 slow jet and did not change the main jet. Was coughing on the way home from the 1k service. Took it back the next day. They en-richen it a bit and up'ed the idle some. Still, coughs!
Next I played with the idle enrichment screw (the one that is covered up from the factory) and could not tune out the low speed coughing so I talked to the dealer some more. They said that the main jet is fine and that the 45 low should work, but some bikes just won't ever be cough free. Wonderful.
So I ordered up a 46 low and a 185 main off of Ebay for less than $15 to the door. Put them in a couple of days ago and even with this big 46 jet, my bike is still getting an occasional cough at low rpm's. I've tuned that idle mixture screw from 2 turns out to 4 in 1/4 turn increments and it makes no difference.
I give up!
Old 08-15-2006, 03:11 PM
sctusa's Avatar
sctusa
sctusa is offline
ORIGINAL: CoolRide
My 05 1200C does it AND I have had it die in the middle of two intersections! I have heard the same thing it is running too lean.However with only981 miles on it when I bought it it had already had the SEII installed by the dealer it seams THEY would have tuned it properly? I jus rev it a little BEFORE pulling out into traffic, but I will look into richening it up.
CR
Mine has just started doing it the last couple hundred miles. 91-93 octane all the time...Does it when it is well warmed up, but not so much before it gets warmed up. Stalled on me twice at a light. The stage 1 was already done when I got it new.
It is going in Monday for the 1000 mile check up and I told them they need to get the carb farts to quit.
We will see...
Old 08-15-2006, 04:22 PM
mpaquette's Avatar
mpaquette
mpaquette is offline
Mine had the cough for a while. It was when the bike had 0-1200 miles on it. The only way to cure it was to run with the choke out thus fouling the plugs; catch-22. Once I had it in for it's 1000 mile service it stopped. It will do it slightly in cold weather but only if I don't have the choke out far enough. You have to find the balance point. If yours is really bad then the dealer needs to do some adjusting.
Old 08-15-2006, 09:57 PM
Broken Leg Rider's Avatar
Broken Leg Rider
Broken Leg Rider is offline
My 91 883 caughs once each morning as it reaches the low end of being warmed up. Still, it startles me every time. I am runnng 93 Octane and get 55 mpg, so I guess it is lean.
Old 08-16-2006, 09:30 AM
brendajmull's Avatar
brendajmull
brendajmull is offline
I have had pretty good luck with the carb not farting much anymore, dh did just adjust the idle screw. Ihave put on cycle shack slipon about the same time so maybe that helps. I just run the first 2miles with the enricher out about 1/4 to 1/2 and then push it in and so far so good.
Ozark Joe
EVO
43
12-03-2015 03:20 PM
Pfarley1
08-06-2014 11:47 PM
1badcj8
01-20-2014 10:41 PM
HollWood
07-23-2009 06:49 AM
tmr931
Ironhead
09-20-2007 01:14 AM
Quick Reply: does anyone else have a 2006 with carb cough?
