Ok laugh away but
RE: Ok laugh away but
Just to make you feel better: Last week, my neighbor came over with his new '98 Sportster and was asking me if it sounded funny. I couldn't hear anything that sounded out of the ordinary, so I told him not to worry about it and if he thought his was bad he should hear my '88 ElectraGlide Sport when it gets good and hot, that thing will tick and clank and sound like it's gonna fall apart. Now to this he responds by expressing some disgust with the way Harley's are engineered by pointing out how small the radiators are on our bikes. Get this, he was pointing at the voltage regulators.
* LEARN how to switch to reserve while on the road ! It will sputter and / or get really quit.........
TAKE the MSF course, it will teach you lots of stuff, probably might even keep you from dropping the bike and may even save your life.
REALLY good stuff, in the course (and I started riding in '72....) !
- with my '05 883, look for gas at 100 miles (I use trip B), hits reserve about 125 miles. I drive highway and heavy traffic to get to work and back (and I definitely twist that grip, when I get the chance...).
my .02 cents.... ENJOY THE RIDE, BE SAFE !!!!
ORIGINAL: outdoorgirl57
You keep riding until it starts bucking and sputtering like it is going to die on you. That means it IS going to die on you until you flip the **** to "reserve" on the fuel tank. (Make SURE you practice and know where that **** is for when you need it.) Then you get yourself to a gas station, as you don't have a lot of gas left in "reserve". Make sure to flip it back to "on" and not leave it on "reserve" when you fill up, or you WILL be out of gas the next time. You figure getting somewhere around 50 MPG (maybe go low at 45), so just multiply that by how many ever gallons on 883's tank is to give yourself an average range of your tank. On the 1200 you have 2 electronic trips meters, so you can use one of them to track your gas mileage. I don't know if that is true on the 883.
I had 101 miles the first time my bike went on reserve.I started filling it up at 80-90 miles after that.I was suprised when i was jumping on it lot and went on reserve at 48 miles.Maybe I reset the trip odometer I don't know but I can tell you if you romp on the bike the mileage will drop fast.The instructions harely provides for usin ght eenrichener are not the ones to follow.If you do your plugs will foul quickley.Only pull it out enough for the bike to start.Then keep it running with the throttle and push it in as fast as you can.You will find temperature has a lot to do with that.When holding the thottle you will hear the engine gain speed,that lets you know it's ready to ride.It will be warm enough to pull out safely.
As another post stated: don't use the "enricher" !
If it is really cold, just use it for the first 20-30 seconds, then hold the rpm with the throttle.
If it is not cold don't use it at all (just a 1/4 turn on the throttle, let go and hit the starter and you should light right up),
the enricher will foul the plugs (really quick) !
Well I don't HAVE my Sportster yet (I wish I did) but I've owned many different bikes. I always make sure my tank is TOPPED off by holding the bike straight up and getting every drop of gas possible in the tank, then I zero the tripometer. After I've gone over 100 miles I TRY to stay within a reasonable distance of a gas station. When the bike begins to sputter (on a carb bike) I put it on reserve and look at my mileage. (On a FI bike I look for the low gas light) NOW I know the distance the bike will travel on a full tank of gas before hitting reserve. Every time I gas up I always top off the tank the same way and zero the tripometer, it's now my gas gage! If I hit reserve at 150 miles I look for a gas station at around 120 miles and that gives me an extra safety net. Simple and probably more accurate then motorcycle gas gages!
And if you HAVEN'T taken a motorcycle safety course yet ... TAKE ONE! Personally I think it was the best money I ever spent!
