Clutch feel question
OK, this has been bugging me for a few weeks so I want to see what everyone else says. Lately I feel like my clutch handle has to be let out about 2/3's to 3/4's of the way before I get into the friction zone. Just as I'm about to let the handle all the way out the clutch feels like it is fully engaged. It does not feel like the clutch is slipping. For some reason I feel like it used to start engaging earlier, like half way. I've made sure my cable is adjusted to spec and made sure that the clutch is adjusted and then readjusted the cable back to the 1/8" of play spec. Am I just retarded or does your clutch start to hit the friction zone sooner?
When you were adjusting the clutch how far did you 'back out' the clutch adjusting screw?
I don't like to back it out more than 1/2 turn, even though the manual might recommend 3/4 to 1 full turn.
If you back it out more than 1/2 turn you will probably experience the issue you described with the 'friction zone', even after proper adjustment of the clutch cable.
Mine does the same thing and it bugged me for a bit too, but use to it now. I asked the HD dealer and they said it's normal and I had a buddy ride the bike that knows alot about HD's and he loved the feel of my clutch. I can tell you this-you do not want to cluch that grabbs right off the grip-that sucks in it's own way.
Sometimes I wonder if some of the 'dealership mechanics' even know how to adjust a clutch.
Friend of a friend stopped by not long ago, and asked me if I could check out his Softail Duece. It had about 12,000 miles on it and he said the clutch has never felt right, even though his dealership checked it out many times.
I rode his bike and the clutch would not start to engage until the clutch lever was almost fully released (from the bar). I don't think the clutch was fully engaging even with the clutch lever fully released, and on hard acceleration you could feel it start to slip.
Pulled the derby cover, checked and found the adjusting screw was backed out over 1 1/4 turns.
Seated the adjusting screw, backed it out 1/2 turn, adjusted the clutch cable, and now the clutch hits the 'friction zone' and starts to engage when released about an inch from the bar, like it should....
The guy rode his bike and was as happy as a kid in a candy store...
Makes you wonder........
Also, do the adjustment when the primary is cold, not after you have been riding and the clutch/primary is hot.
Just turn the adjusting screw in until you feel resistance, kind of like when you are putting a nut on a bolt and it starts to 'snug up'. I usually turn the adjusting screw in until it starts to become snug, back it out again, and do it a couple more times to make sure I'm getting a true reading.
Once it's snug (not tight) back it out between 1/4" to 1/2"... Like was mentioned in an earlier post in this thread, if you only back out the screw 1/4" the clutch will start to engage sooner when you start to release the clutch lever. At 1/2" the clutch will start to engage a little later when you start to release the clutch lever. It's all a personal preference.
After that just readjust your clutch cable, leaving a 1/16" to 1/8" gap between the cable ferrule and the clutch lever bracket. We never bother to actually measure the gap as an old trick is to just leave a nickel or quarter width worth of gap.
After that you should be good to go....
