Bike wont shift
Bike wont shift
Hey their the names bill im new to this form and was looking for a little bit of help. I have a 1988 sportster that has been running great and shifting great but latly I been haveing some trouble. I noticed as im driving ill shift and the bike will shift into gear fine and it will start to go but will rev up and not give me full power. So I dont know if the clutch is sticking or something im just not sure. Now the bike wont even drive it just shifts into gear but when i release the clutch it just dosent go but i hear it shift into gear it makes that little clunk noise. Any help would be great thanks
Almost sounds to me like your clutch is slipping.. and bad.. I would check it out.. and see if there is any ware and tear on it.. and welcome to to forums..
and check a manual and see if it has any suggestions for you..
Your description was hard to understand, but if I'm getting the main point...
You put the bike in gear, let out the clutch, and instead of the bike moving forward(or moves slowly), it just revs up?
That's your clutch letting go. You need to replace the friction and prolly metal plates as well. You'll need to look at 'em to find out for sure.
I would say either Harley or some where like JPCycles.. or someone like that.. with a clutch I would try to avoid someone that you don't know.. or trust.. As far as changing it im not really sure how hard it is.. I too have never done it.. but I would say first off if you dont have one get a manual for your bike.. and go from there.. its got to be easier then changing one on a Honda civic..
worthymccormick
01-30-2010 08:40 AM
