Head light
Head light
How do you change the bulb in a 883 2003?
Do you have to take the headligh assembely off?
All of a sudden my headlight doesn't work, the brakes work, the turn signals work but the headlight went out.
I put some drag bars on while I was changing them everything worked as soon as everything was done it stoped working what gives?
RE: Head light
Here is the deal checked the turn signal wire / well i ended up screwing them up by crimping them with the clutch clamp.
tHE FUSE WAS REPALCED but the head light still does not work and there is also no runing light in the back, the brake light works when you use the brake.
What gives need help.
Also what kind of replacemnet headlight bulbs do you guys use?
