When you guys did your ignition and coil relocate did you have to...
Did you have modify the lengths of the ignition wires to the rear cylnder???? and the coil wires???? any lengthening of shortening???? I know one of the plug wires will be to long...I'm talking about the actual wiring....I'm cool with moving things around...but I like to stay away from splicing and whatnot....Thanks...
The only thing will need to do is buy two new sparkplug wires, the ones that work are off a Harley Rocker. all other wires are long enough to move around where you want them.
awesome......thanks....I also have a tank lift....and I will so be pushing the wiring up in the tunnel....Are all those wires long enough to be thoughly stuffed with a problem??? Thanks..
i think a stock sportster front cylinder spark plug wire will also work.
