HD proximity key
HD proximity key
Quick question about the proximity device that must be on you if you want to start the bike. ..
How hard would it be to use the system and switch the bike to "keyless" where all you would need to do is walk up to your bike with the device in your pocket and start it up... Anyone done this or tried to?
why would you want to do this? you would have to wire around the safety neutral switch. then if you parked your bike in gear (on a hill) as soon as you walked close to it, it would run off. There is a system for cars you can buy at wal mart, I am sure you can wire it up to a bike. I wouldent suggest it though. although it does work on a button
I just figure since the dealer explained to me that the system pretty much shut off all the electrical stuff off the bike when you walked away that if your bike was wired to "run" if YOU weren't close to the bike with the perimeter device it wouldnt start anyways..
But my knowledge with the system is super minimal.. I just got to thinking when the dealer was explaining it to me. It reminded me of the cars that have push button starts where you only need the key in your pocket
I have the proximity type security system on my softail and it sucks. If the battery in the fob goes bad you stop. If the fob is close to a cell phone you stop. If there is some sort of radio interference you may stop. I would much rather have the button type to engage or disengage the system.
