Anyone know how much stock slip on's weigh?
Just curious, does anyone know the weight of the stock slip on's (on an 09 XL1200C).
Read somewhere that an exhaust change to an aftermarket not only gives you the opportunity for a hp gain via a Stage 1 type modification, but this poster said his exhaust system was now 20 lbs lighter (that weight loss could yield as much as a 3 hp gain because of the engine displacement to weight ratio ). When people are saying their stage 1 really made a difference, I am thinking weight may also have come into play?
kinda supports what this guy said...
That kinda supports what this guy said, "He said when he replaced his stock exhaust not only did he get the gains on the free flow compared with stock, but he lost 20 lbs. of weight (that weight loss could transfer into the "feeling" of an additional 2 to 3 hp)... Something to consider. I saw an Amazon ad that quoted a shipping weight of 22 pounds for V & H slip on's. I wonder what the stock would be (shipping weight)?
I know the V&H slip-ons are lighter because I had one of each in my hands amazed at how much lighter they were than stock.
Unless my scale is way off... the weight loss is going to be closer to ten pounds.
I have my stock slip on's and a trashed set of Cycle Shack slip on's. I suppose I could check, and compare. But if you're that hung up about the weight and performance, just skip the cheeseburger, leave the bitch at home, etc etc.
I really don't think there is that much difference in the weight
I don't think there's any measurable performance gain from a reduction in sprung weight. Especially with such a small reduction. If the wheels (un-sprung weight) were three pounds lighter that would probably be measurable in terms of acceleration. One gallon of gasoline weighs six or seven pounds (I think) and I can't tell any difference when I'm half empty.
Facts are that stock Nightster/Iron exhaust system weighs 22.5 lbs.
A V&H comp series 2:1 weighs ony 4.7 lbs.
That saves almost 18 lbs but offers only less than a pound of advantage per horsepower. The real gains are made afer installing the pipe and retuning.
That's why I just ordered the V&H comp 2:1 plus N4 cams, plus stage 2 heads plus 1250 kit.........Soon I will have 6.5 lb/hp vs present 12lb/hp.
Engines operate on math. Learn to do the math
