How Do You Store Your Sporty For The Winter
Old 09-22-2009, 05:23 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
Thumbs up No Doubt ...
[QUOTE=xxxflhrci;5609170]The worst thing you can do is start it and let it sit and idle. All you do is foul your oil.
Seems no matter you you say to some They Just don't get it .. All Idling an engine does is create enough heat to add moisture then shut it off and let the contaminates go to work .. If Going to Run it... Run it hard for an hour or don't run it all .. When spent a few Winters in North MI ( where wife was from ) Drained the Oil, Put in Fresh, Park on 1/4" piece of Plywood, Put in on the Tender, Wiped down all areas prone to Rust with WD 40 and left her be..
  #32
Old 09-22-2009, 09:02 AM
3rdgear's Avatar
3rdgear
3rdgear is offline
+1 to to wd40... surprisingly enough.. I have a Yamaha 650 Classic that was submerged in about 4 1/2 feet of water during Ike.. WD40 really helped keep the chrome from rusting.. I was really surprised..
  #33
Old 09-22-2009, 11:36 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
Originally Posted by TBirdEd76
Seafoam is 100 times better than normal fuel stabalizer, i love that stuff.
Seafoam is great stuff, I use it as part of my regular 5,000 maintenance routine. But, to my knowledge, it's just a cleaner and has no fuel stabilizing benefits.
  #34
Old 09-22-2009, 02:06 PM
hogsport's Avatar
hogsport
hogsport is offline
+10 on the "ride it a couple times a month". With your '08 you will want a tender. The alarm drains a battery in a few weeks.
Swamp Donkey
10-30-2016 09:50 AM
Swamphunter
09-19-2014 06:08 AM
MN_RoadKing
11-12-2013 12:43 PM
timdvm
12-24-2007 05:04 AM
AwfHand
11-08-2006 02:23 PM
Quick Reply: How Do You Store Your Sporty For The Winter
