If HD does it, "Stage 1" is kind of pricey...
The service guy got back to me on my stage 1 install questions/quote.
If my local HD folks do it it's $460 for the stage 1 SE kit installed and the remap and he offered these pipe options (and SE):
RINHARTS 665.00 INSTALLED
KERKERS 620.00 INSTALLED EHX TIPS ARE INCLUDED
RUSH 1 PIECE 480.00 INSTALLED
RUSH W/ TIPS 650.00 INSTALLED
So it would be as high as $1,100+ and then plus tax.
Question is what do you think a similar upgrade would cost at an independent shop?
Since the stage 1 remap is worth about $150.00, that means your paying $300.00+ bucks for the (plastic) SE A/C installed.
Why not use an Arlen Ness BS which is ~$150.00 and a set of Cycle Shack Slip-On's at ~$150.00?
The install is pretty easy, but if you can't handle it, an Indy could probably install the pipes & A/C for ~2 hours labor.
All I know is that it was gonna cost me around $1600 to have a local custom shop do mine (with V&H) the dealer was more expensive than that as well. That's when I said SCREW IT and chose to do it myself. I saved over $400 on the pipes alone and installing them myself. next comes the tuner and the intake change. Those are my winter mods
My advice is to do the complete stage 1 yourself and save a butt ton of $$$$$. Adding the tuner will have to put it on the Dyno to get the correct air/fuel mixture. once you have it fine tuned on that machine it will run much better and cooler. the upgrade is very easy and if you can turn a wrench you will have it done in no time all.
stage 1 upgrade...
I went with SE slipons, and the SE stage 1 air...found web sight(Harley dealer online) 20 % cheaper than local shops. Got a local shop to price match - so roughly 115 for breather kit, 210 for exhaust, installed myself in about 1 1/2 hours(wife kept talking to me - she's good at that). The dealer did stage 1 download for $150 no labor since I bought parts there. So about 475.00 give or take for all and can't believe how much better bike runs.
Gonna add a few other mods, RK shocks and Flyscreen next week.
Then maybee in a year or so when I can afford it - V&H straightshots, V&H Duke, and SERT with Dyno...
Try wheeling and dealing with the dealer...
Silly Question (but I don't know) if I have an independent do the air cleaner & the pipes what does the bike run like until I do the remap at the dealer if the independent can't do the ecm/efi remap when he does the pipes and air cleaner?
My wrench limits...
Maybe if I read up more on Arlen Ness "Big Sucker" installation & Cycle Shack slip ons I might feel like giving it a try (the difference in cost is a lot).
The tuning after those installs would be another thing. I don't have a clue on that stuff. The bike is running so nice right now... I don't know?
Sure I'd like a bit more oomph! (I just came off a bike with a 100 hp); but I do not want to screw this Sportster up.
I will mull it over for a few days
I didn't ask the Independent fellow if he could do the remap (is that a dealer service only)?
It's better to run a little rich in between the 2 steps than too lean in between.
Hadn't read your post until just now!
Your words "...and can't believe how much better bike runs..." is an enticement! The independent told me the difference wouldn't be that much (not real enthusiastic, he said do some head work). The HD service guy wrote "gains to be somewhere around 8% to 12%".
I ought to be able to feel even an 8% overall increase in power, no?
OK now I am understanding the sequence of events...
I am not familiar with HD dealers; can I hand them an Arlen Ness Big Sucker Air Cleaner and a set of Cycle Shack Slip Ons, and say install these and remap (or will they only install what they sell)?
