primary oil
Old 09-09-2009 | 05:31 PM
hdjimi's Avatar
hdjimi
Stage III
Default primary oil
i was draining the primary oil out of a 75 sportster and about 1 1/2 quarts of oil came out from the primary drain plug and there was hardly any oil in the oil tank itself. Where could all this oil come from? could it be the primary crankcase seal?
Old 09-10-2009 | 03:04 AM
XLCR4GM's Avatar
XLCR4GM
Yes, it could be and it may be from the Crankcase seal being faulty.
Old 09-10-2009 | 08:39 PM
hdjimi's Avatar
hdjimi
Stage III
thanks. is that the only place it could be coming from?
Old 09-11-2009 | 01:47 AM
XLCR4GM's Avatar
XLCR4GM
Well, the empty or near empty oil tank could just be because the bike has a leaking or bad ball check valve in the oil line. What happens with that is if left for a time, the oil will, because of gravity, seep down into the motor. Once the motor is started up and running, it will pump the oil back up into the oil tank again. It is not a problem per se, but more of a nuisance kind of thing. It won’t hurt the motor, although it can make the motor hard to start. If the ball check valve is leaking and all of the oil in the oil tank leaked down into the motor and the crankcase seal is bad or leaking then that could well be where all of the extra oil came from. It also could be because the primary case was over filled to begin with too! Other than that, I can't think of any place else that the oil could have come from. Good luck with your bike and ride safe!
300sd1982
EVO
06-21-2017 09:48 PM
bennenrkc
Ironhead
06-18-2014 11:32 AM
duallram03
EVO
10-13-2013 09:19 PM
madman13
Oil Archive (no new posts)
10-02-2012 09:57 AM
mrford55
02-15-2011 08:03 PM
