High Beam in the Trees!
If the high beam is too high, then so is the low beam. there is only one bulb in the headlight housing.
To adjust your light, the bike needs to be on a level surface 25 feet from a wall. With you sitting on the bike, the center of the beam thats shining on the wall should be35 inches from the ground.
Read your owners manual for instructions on how to move the beam up/down and lrft/right.
This should have been done at the dealership as a part of the setup.
