Has anyone uupdated the stock carb on their sporster? If so, did you notice a performance improvement enough to justify the cost? Been reading about S&S.
i run a s+s super e on my 83 ironhead. the bike came with the carb, and it seems to run pretty good. also the carb is pretty simple to work on as far as adjusting and changing out jets and stuff. hope that helps out some!
Unless you go at least a bit beyond Stage 1 (like with some head porting and/or hotter cams), a carb won't probably give the benefit it could (maybe a little easier tuning) although it won't hurt. The stock CV carbs are actually not bad. For an upgrade I like the Mikuni carbies - thinkin' I'll probably go to a 42 (the Mikuni HSR 42) when I do my 883-1250 conversion. Just my 2 cents!
