removing a battery
Try one of these. I found them by using the search function in the blue bar above ^^^^^^
https://www.hdforums.com/forum/sport...y-removal.html
https://www.hdforums.com/forum/sport...tallation.html
P.S. Welcome to the forum.
A service manual would be your best bet! The battery is behind the left side cover. The cover is held on by a couple of little plastic clips. Pull the top of the cover (out) toward you to release it from the clips. It can pivot down and hang by the bottom part of the cover. The battery has one cable (+) facing you and the other cable (-) is away from you on the inside of the battery compartment. Pull off the main fuse first to disconnect the battery from the wiring harness then disconnect the (+) battery cable. I found it easier to disconnect the (-) battery cable by undoing it from where it grounds/connects to the engine close to the starter motor, then I could pull the battery out from the battery compartment and feed the (-) cable from the other side through the right side cover. There are some instructions on the inside of the left side cover after you get it off that may help you too! Get a service manual! Good luck and ride safe!
The guy has 4 posts, get off his ***. He probably isn't all that familiar with the way forums work.
I used to hate people like you, until I figured out how these things work. Different forums have different ways and things you need to click and switch around in order for them to work. Some are very simple. If you don't want to help the guy out. Don't answer the question. No reason to be a smartass.
thanks
