Disandvantages to removing belt guard?
not really, if yr runnin a passenger offten it might be important so there pant leg doesn't get sucked in but besides that....nope.
some will say it will keep rocks and **** from getting into the pully or debris hitting you but i really think thats a bunch a bull ****. i've never had an issue.
don't forget to remove both the upper and lower for a better look....and while yr at it remove the pully cover, its like 3 bolts and makes it look better too
But if you want to remove the upper, you have to undo the bolt on the rear shock. The upper chain guard is attatched under the nut holding the shock on.
Well, it IS three bolts...
Providing you've also already removed your rear pipe.
You can remove the 3 bolts easily, but you won't be able to remove the pully cover with the pipe in place.
I'm telling you this all from the past hour of experience, since I was inspired this morning to do some wrenching on my Iron, also.
and if you don't ride in gravel much, there are no disadvantages to taking the guards off.
