Roadking rear shocks for sportster
Old 01-22-2016, 01:56 AM
jandy2640's Avatar
jandy2640
jandy2640 is offline
I refilled mine with 9 oz of Mobil 1 transmission fluid which is about 7.5 wt. They work great.
  #92
Old 01-22-2016, 11:52 AM
ev0lution7's Avatar
ev0lution7
ev0lution7 is offline
I drained mine and filled it with 10wt belray SHOCK oil 10oz ea and installed a shrader valve between the seat and tank on the frame, I also replaced the Plastic air fittings on the shocks with ALL brass ones from a "hose shop" they sell Big rig air line fittings:
  #93
Old 02-21-2016, 11:45 AM
Barthel75's Avatar
Barthel75
Barthel75 is offline
Originally Posted by sidecar1273
It is 5/8 washer. I went to tractor supply and were the have hitch pins they also have 5/8 shims. A little thicker than washers and outside diameter is smaller also. Btw in the tire slime area the have 2 packs of slime valve stems that fit the shocks perfect
I went to tractor supply could not find screw in valve stems only the pull thru ones
  #94
Old 05-10-2017, 10:02 PM
j2mao's Avatar
j2mao
j2mao is offline
Stage I
I have 2012 HD 48 and thinking of putting a Road king shock ( 54565-97C ) my mechanic said it wouldn't work since i'm only 150 lbs. and 5'5" ht.
I'm also considering a "TEC" shocks with a piggy back 12.3 in length.
pls help.
  #95
Old 05-11-2017, 02:19 PM
TStephen's Avatar
TStephen
TStephen is offline
NAPA
$1.80 each.
https://www.napaonline.com/en/p/NTH90290
FortyEighters
Sportster Parts
03-13-2020 04:00 AM
diddy0230
Sportster Parts
17
03-02-2014 11:19 PM
xl8832007
05-18-2013 11:27 PM
SHU
09-11-2006 11:50 PM
salgood
08-13-2006 11:33 AM
Quick Reply: Roadking rear shocks for sportster
