I lost my rear fender!!!....
hey akracing.. I placed the ECM in the gap between the oil reservoir and the fender, I basically shamelessly stole Slackster idea (and the photo too.. :-) here is Slackster take:
mine is a little bit different, instead of cable tie wrap, I used a couple flat metal pieces with holes, secured to the ECM with stainless steel nuts and bolts, I then secured the metal pieces to the top two bolts that secure the oil reservoir... I will do my best to take pics tomorrow...
I have been also thinking about replacing the battery with a much smaller one... I saw a small motorcycle battery at Advance Auto Parts for $30... I am certain is small enough to allow the ECM and battery to share the battery compartment... I will let you know if I go that way..
