Pre Loading Stock Fork Springs
Old 08-01-2009 | 01:54 PM
tinman67's Avatar
tinman67
Default Pre Loading Stock Fork Springs
i have an 08 sportster 883C. I am looking for something to give a little pre load to my stock fork springs. Anybody know a wat to do this? If necessary I would go to a heavier spring. Don't really know where to go there either. As it is, when I sit on the bike the front drops about 1/2 the distance of the fork travel and I would like it to be closer to 1/4. Any info would help.
Old 08-01-2009 | 08:23 PM
1200Cdriver's Avatar
1200Cdriver
Tin, I put Progressive Fork Springs in my 2007 1200C and used the supplied spacers at their full length. Doing that and using 7w BelRay Fork Oil gives me a very good ride up front.
I used this device from Progressive to adjust the oil level to the prescribed amount.
http://www.progressivesuspension.com/tools/index.html
Click on picture #2.
Old 08-01-2009 | 09:09 PM
cHarley's Avatar
cHarley
Originally Posted by 1200Cdriver
Tin, I put Progressive Fork Springs in my 200& 1200C and used the supplied spacers at their full length. Doing that and using 7w BelRay Fork Oil gives me a very good ride up front.
+1 Well worth the ~$80.00
Old 08-01-2009 | 10:28 PM
HarleyScuba's Avatar
HarleyScuba
I use one of these. About $30-
I've also used a 14" carraige bolt, a black Sharpie and patience. Free, but not as accurate.
http://www.motionpro.com/motorcycle/partno/08-0121
Old 08-01-2009 | 10:30 PM
RacingJake's Avatar
RacingJake
Use some thick PVC pipe cut to length. Try 1 inch long first and see how she sit's.
Only problem is screwing the fork caps back on if it's too long. Just make sure you have the front wheel off the ground.
Old 08-02-2009 | 06:31 AM
1200Cdriver
I used the 3" spacers that came with the springs, they are spot on perfect.
Bagger Jim
09-07-2011 11:21 AM
creep1
03-28-2009 02:48 PM
ssls6
04-01-2008 11:36 AM
hogbag07
01-06-2008 11:04 AM
hogbag07
01-05-2008 01:21 PM
Quick Reply: Pre Loading Stock Fork Springs
