Does anyone make an alternate brake arm/lever for Sportys?
Just curious if anyone knows of a company that makes an alternate brake lever...one that work with various brake pedals. I see tha pedals and levers for big twins but never sportys
You can purchase a brake pedal cover for a softail and modify your existing pedal to make it fit. All you need is a drill bit to drill a hole in tour existing pedal and a dremel to grind down the bump on the bottom of the pedal so the screw fits straight and tight.
Ill have to look into that...I haven't really looked at the pedal covers for the Big Twins to see how they would attach but Ill just pick one up and play around.
I just put a Kury rear brake pedal on My 06 and I really like it. Search rear brake peddle ? and it should pop right up. Mine matches My Kury pegs & stirrups . ..WVleo
