turn signals stopped working
Old 07-26-2009 | 12:05 PM
McGowan128's Avatar
McGowan128
Stage IV
Default turn signals stopped working
any one know where either the fuse or turn signal module is located on a 2000 1200 c, I cant find either. thanks
Old 07-26-2009 | 03:14 PM
killer scott's Avatar
killer scott
Under the battery cover. Might want to look under the rear fender... If you hit a serious bump, you may have torn those wires under there. Also, they plug in behind the tail light. Might be worth a look as well. GOod luck. Hopefully a fuse.
Old 07-27-2009 | 07:09 AM
WVHogRider's Avatar
WVHogRider
The fuses are located under/behind that triangle cover just to the rear of the battery. Just pull that off as it just pops on & off with some bars that go into some rubber grommets on the frame. And as Killer stated, if you hit some large bumps you may have torn a wire under the fender that go from the rear signals into the fender & run along the side wall of the tire back to the rear brake light.
Old 07-27-2009 | 12:45 PM
McGowan128's Avatar
McGowan128
Stage IV
Default Blinkers
Ok, I looked everywhere for a fuse and I can not find one, yesterday I took it to a friends house, we took out the bulbs and they were full of grease we wiped them off and they worked for about 5 minutes, I am at a loss, I looked under the fender for frayed wires and they look good.
Old 07-27-2009 | 04:07 PM
midnight2005's Avatar
midnight2005
Have you checked your blinker fluid? If it is low they will not work at all.
Old 07-27-2009 | 07:50 PM
killer scott
SONOFABITCH............
I didn't even think of that! How obvious. Good call.
Old 07-27-2009 | 09:15 PM
stng_96's Avatar
stng_96
I cant believe it took this long for someone to make mention of this.
Old 07-28-2009 | 06:38 AM
WVHogRider's Avatar
WVHogRider
That grease is dielectric grease, (blinker fluid ), and is in there to keep the contacts from oxidizing/corroding. Are you sure the bulbs aren't just blown? I say this because the filament may have just made contact again when you took them out & put'em back in.
oletyrone
10-09-2016 04:32 AM
Kailua Knight
10-15-2015 11:11 PM
BrysZ
Electrical/Lighting/Alarm
07-13-2015 06:27 PM
103 st bob
06-28-2012 11:53 PM
tincup64
04-11-2010 07:09 PM
Quick Reply: turn signals stopped working
