Exhaust whistle
Old 07-21-2009 | 02:05 PM
NIGHTSTER24's Avatar
NIGHTSTER24
Default Exhaust whistle
I have an 07 nightster and i just put on V&H straight shots and once in a while when i ride i will here a whistl ecoming from what i think is the exhaust. It only does it when the bike is not warmed up from what i can tell and only when riding not at idle. When the bike warms up it goes away any thoughts? Thanks
Old 07-21-2009 | 02:40 PM
MaroSteve's Avatar
MaroSteve
did you replace the gaskets? possibly the gasket is not seated correctly and eventually the heat forces it ****.
Old 07-21-2009 | 04:53 PM
drum412's Avatar
drum412
Have you considered it comming from the brakes? Your brake pads warm up with time also which can relate to you thinking that it goes away with engine warm up. Next time you hear it, try giving your brakes a fairly hard squeze, and see if it stops the whistling, and maybe try each brake seperately to isolate which one it may be. Being the brakes would also explain why it only happens while riding too. I often get a good whistle from my rear brakes if i'm accelerating with the bike leaned to the left in a long turn.
Old 07-21-2009 | 05:32 PM
LoneStarSkater's Avatar
LoneStarSkater
Crossover gaskets
Old 07-21-2009 | 06:27 PM
xFreebirdx's Avatar
xFreebirdx
Originally Posted by LoneStarSkater
Crossover gaskets
+1
Son of PMS
EVO
08-31-2014 10:10 PM
Robert Strohl
08-18-2014 08:06 PM
insnedrmr
05-23-2007 09:35 PM
dsuppa
08-10-2006 06:32 PM
ebaswell
03-04-2005 09:21 PM
Quick Reply: Exhaust whistle
