Hnadlebar Vibes
Seriously, though... Slipping some weight into the ends of the bars will change their resonant frequency and that might help take some of the buzz out. If you have internal wires, you will need to consider their routing when adding weight.
Here's a product that some people seem to like, but I have no experience with them.
http://www.barsnake.com/
For about a little less than $100.00, I bought and installed a set of Vibranators, putting one in each end of the handlebar on my mostly stock 1999 XL883. (Stage 1 stuff you know, A SE Ignition Module and a SE Air Cleaner and a RB Racing 2 into 1 Exhaust pipe along with the addition of a 30 Tooth Transmission pulley) They do seem to work well. At idle I can see and hear that the vibrations in the handlebar are much reduced and on the road I can really tell the difference. The buzz in the mirrors at all speeds, especially at highway speeds, is greatly reduced as is the buzzing in my hands. I would normally shift long before the Rev Limiter kicked in because of the increases in vibrations through the handlebar, but not now. I can now increase the time between shifts because the vibrations are not so intense. It will NOT completely and totally eliminate 100% of all of the vibrations in the handlebar, and they do not claim to either, but it did do a very good job of REDUCING them quite a bit I must say. I have already ordered another set to go into my 2007 XL883 to see how they will work out there. I have not tried the Bar Snake products so I can not comment on it other than to say it is about half the cost of the Vibranators. I also have not tried to put weights, like a role of nickels or liquid nails or expanding foam into my handlebar either so I do not know if that will actually help as much as the Vibranators do. Also, if you ever want to take them out to, say, put them into another motorcycle, I think that they would be much easer to remove than any expanding foam or liquid nails or the liquid version of the Bar Snake as that stuff is, more or less, a permanent kind of deal and I don’t know how hard it would be to remove the original, solid version of the Bar Snake either, or if it even can be removed. In the end, it’s your bike though, so try out whatever you want to use on it and let us know how well it worked out for you so we can all get some new ideas going on in here. By the way, I am just another rider sharing my experience with someone who asked a question. I have nothing to do with the product that I bought so I really don’t have a dog in the fight so to speak. Just sayin…
Funny you should mention Vibranators. I just ordered a set this week and they should be here tomorrow. I have two questions for you. How hard are they to install? Do you have to take the grips completely off, or can you just take off the end caps? And I do have wiring inside the bars, will that be an issue? Ok, that's actually three questions.
Shakey
Shakey
They are VERY simple to install. You just need one Allen Wrench to tighten up one screw in each of the two units that come in the one set.
You do not have to take the handlebar grips off at all. I cut the very end of the handle grip a little bit so that I could peel it up and make an opening large enough to insert one unit into each end of the handlebar. After I tightened each unit up I used a little glue to close the matieral back up almost like new.
If you have some space from about the very end of the handlebar to about 5 inches up inside the handlebar you should be good to go.
