Saddlebag options without having to move turn signals
What is a good inexpensive option for saddlebags on a 2006 1200L. Looking for something that I would not have to relocate turn signals. They do not have to be big as I have the quick disconnect backrest with luggage rack that I can use for luggage. Thanks for your help.
i was opening up this can of worms not too long ago and i finally gave up...at least for now. i also have the quick disconnect backrest and was unable to find a set of bags that would work with the backrest and without re-locating the turns. i even went to a local shop and put the smallest bags they had under the seat and the lights were still in the way
No problem. I have all the carrying capacity that can be safely used on a Sportster. It is all about your priorities. As for saddlebags, you have to accept the fact that you are length limited due to the turn signals, and height limited due to the pipes and passenger. So, you only have bag thickness to work with. So, get relatively thick bags or they will be of little use. I use the compact slant Willie&Max. They are easy to run under the tandem saddle and secure (front to shock mount, rear to signal stalk).
Bags are fine for rain suit, jacket, and small packable items, but that is about it. My big hauler is a bag that mounts (secured on a rigid base) on the rear rack. It folds down to nothing and pops up in a sec to hold three plastic shopping bags of stuff.
I've used hard bags and leather bags--won't make those mistakes again. I look at big twin baggers with their hard bags and tour packs--and laugh. To each his own.
