Can oil be too cool?
I guess the fact that you are thinking of adding an oil cooler indicates that you think that you currently have problems with the oil being too hot. That being the case, go ahead and add one. If you're not having problems, don't bother. I am a strong believer in the old adage "If it ain't broke, don't fix it".
Try an oil temp dipstick first to see if you need and oil cooler (it's a lot cheaper). The question of can the oil be too cool applies to running in cold weather. The answer there is yes. Colder engine and oil temps can cause condenstion in the oil. Different oil weight can be used to keep the oil temp up and Harley reccomends oil changes at 1k when running in cold weather. Not so much a problem if you run long enough trips to get the engine up to temp.
Can oil be too cold? The answer is yes. Colder temperatures effect how oil flows. That is why oil is made in different weights. eg....5 to 30 weight. In colder climates, you would run say a 10W or possibly a 5W because the oil is thinner and will flow better at cooler temps, compared to 20W which is thicker (ideal for hotter climates). As far as an oil cooler is concerned....they don't actually make the oil cold to the point of restricting oil flow. They simply work like a radiator by circulating (hot) oil from the motor through passages/cells which are cooled by air passing over the (radiator) cooling fins. Then the oil is fed back through the motor again, where the entire process is repeated all over again.
Get a thermostatically controlled oil cooler..the oil dosnt circulate thru them below a certain temp...
I have the thermostat on the dipstick and right now the temps never seem to get above 220. I haven't been in extended traffic, though. I'm thinking long-term benefits like reducing oil breakdown and general engine health.
Bike week in Daytona may be the ultimate challenge. I'd rather spend a couple hundred bucks on my terms than several hundred on a mechanic's.
Living in Florida, I won't really have any cold weather issues. I just want to know if a cooler oil temp could do any damage.
Your oil needs to run at a temp of 180+ degrees to get rid of moisture that accumulates in the oil tank.
